Working with Matrices in MathCad
Hoping someone here can help..
I have a equation, say: P=(q*t^a)/S
I want to vary P with t and I would like to populate the first column of an array with t values, say 1..75 (range variable) and then populate the second column with P assuming q, a and S are static. Then I would want to find the time, t at which the pressure, p fell below a certain value.
How do I do this? I can find plenty on how to mess about with an array (transposition, etc.) but not much on how to work with one with equations.
James
Simmantix
Phases of a Project:
Exultation, Disenchantment, Search for the Guilty, Punishment of the Innocent, Praise for the Uninvolved...
RE: Working with Matrices in MathCad
Thankyou, succinct and to the point..
Simmantix
So.. Additionally, is it possible to fill each column of the array with different data in the same way as above. So the first column would be P1, the next P2 and so on?
Or do you have to create seperate arrays and Append them together?
Thanks, james
Simmantix
?? As written above, P is a single column array of 76 values.
Recent versions of Mathcad will not allow you to mix units within a matrix, so you would have a single column array t, consisting of 76 values, and a column array P, consisting of 76 corresponding values. You can stick everything in a two-column array if you are willing to divide out the units, but units are what Mathcad excels at.
TTFN
Fair enough but if I wanted an array of partial pressures, same units then how would I populate the second column?
Simmantix
