ductileûbrittle transition temperature
Materials is not my area of expertise so I have a question:
Say we have two specimens of A36 steel. The first has a ductile–brittle transition temperature of -20 degrees celcius and the second -10 degrees celcius.
Does this suggest that the first specimen will have a higher toughness at higher temps, say above 0 degrees celcius?
RE: ductileûbrittle transition temperature
In general you can't say that a material that has a lower DBTT is going to be necessarily tougher at higher temperatures.
Look how complicated the relationship is between steel variables and DBTT and toughness- you aren't going to get a standard relationship.
http://www.sut.ac.th/engineering/metal/pdf/MechMet...
http://www.eng-tips.com/threadminder.cfm?pid=1529
Use translation assistance for Engineers forum
Note the rules include No Student posting
