(ask) recommend books reinforced concrete and prestress concrete
hi all,
i need your help, what is the recommended books for study of reinforced concrete and prestress concrete which using SI units for beginner to middle ya?
M.A.
RE: (ask) recommend books reinforced concrete and prestress concrete
That will probably require two separate books.
For prestressed I can recommend "Design of Prestressed Concrete" by Arthur H. Nilson, if it's still available.
I found the textbook for the reinforced concrete I took to be confusing so I won't list it.
I agree with Archie264 that you will require two books.
For reinforced concrete, I recommend "Design of Reinforced Concrete" Seventh Edition by Jack McCormack. It is an old edition (ACI 318-05) and is available at a very reasonable price used from many sources.
Prestressed Concrete by T.Y Lin and Ned Burns, still available. Very extensive and easy to understand.
What code?
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
for code using ACI
M.A.
