Spur Line Tension
Spur Line Tension
Spur Line Tension
Gents,
Could you advise whats the recommended tension for a spur line (7/4.5 AAC) that T-offs (80deg deviation) from a pole with 200m span of 30/7/2.50 ACSR on each side and with existing tension of 18%? Should it be 18% too?
regards,
Danilo
RE: Spur Line Tension
Hi 7anoter4,
Thanks for your replies..Could you advise please the specs (brand) of dry buzz stick or any other instruments they use to measure the sag?
Many thanks
