Custom CAM toolpaths in siemens NX
Hello everyone.
I've been searching some sample codes that can provide examples about drpos, dpud, udop functions, used to create custom toolpaths in siemens NX. I need a code that provide information about use of selected geometries used to create reference for the toolpath which will be created. Follow a code that i created on java to use DPUD function, but i found some problemns, like a infinity loop on generate the operation. Someone can help me?
CODE
public static int dpud(String[] args) throws Exception, NXException {
int retorno=0;
initvar();
UFVariant udpud;
UFVariant operptr;
UFVariant udrpos1, udrpos2, udrpos0;
UFDpud.Purpose purpose;
String opname;
UFVariant pathptr;
Tag operacao = null;
udpud = theufsession.dpud().askDpud(null);
operptr = theufsession.dpud().askOper(udpud);
purpose = theufsession.dpud().askPurpose(udpud);
opname = theufsession.oper().askName(operptr);
pathptr = theufsession.oper().askPath(operptr);
operacao = theufsession.obj().cycleByName(opname, operacao);
//udrpos0 = theufsession.dpud().askDrpos0(udpud);
//udrpos1 = theufsession.dpud().askDrpos1(udpud);
//udrpos2 = theufsession.dpud().askDrpos2(udpud);
if (purpose == UFDpud.Purpose.USER_PARAMS) {
theufsession.ui().openListingWindow();
theufsession.ui().writeListingWindow("USER PARAMS" + "\n");
theufsession.ui().writeListingWindow("NOME DA OPERACAO: " + opname + "\n");
theufsession.ui().writeListingWindow("TAG NUMBER : " + operacao + "\n");
theufsession.ui().writeListingWindow("TAG NAME : " + theufsession.obj().askName(operacao) + "\n");
purposeopen();
} else {
theufsession.ui().writeListingWindow("generate drpos" + "\n");
//retorno = -1;
if (purpose == UFDpud.Purpose.REWIND) {
theufsession.ui().writeListingWindow("REWIND" + "\n");
if (purpose == UFDpud.Purpose.STOP_PROCESSOR) {
theufsession.ui().writeListingWindow("PAROU A DO PROCESSAMENTO" + "\n");
if (purpose == UFDpud.Purpose.TAXIS_PARAMS) {
theufsession.ui().writeListingWindow("TAXIS PARAMETERS" + "\n");
if (purpose == UFDpud.Purpose.PROJ_PARAMS) {
theufsession.ui().writeListingWindow("PROJ PARAMS" + "\n");
if (purpose == UFDpud.Purpose.INIT_PROCESSOR) {
theufsession.ui().writeListingWindow("INIT PROCESSOR" + "\n");
//theufsession.param().generate(operacao);
theufsession.ui().writeListingWindow("GERADO COM SUCESSO" + "\n");
return retorno;
RE: Custom CAM toolpaths in siemens NX
There are lots of code samples there.
https://solutions.industrysoftware.automation.siem...
For a discussion, I think you will have a better audience in the Siemens NX languages forum:
https://bbs.industrysoftware.automation.siemens.co...
Mark Rief
Product Manager
Siemens PLM
Thanks for your repply.
I searched on GTAC Symptom/Solution Database, but i not found a sample code or a sample file that can provide information about dpud and drpos. Only about UDOP. I searched too on the forum that you had recomended, but i dont found what i need.
can you provide me some sample code with dpud, drpos, and another functions to create custom toolpaths on NX that i need?
Thanks for your attention
Please?
you need to add handling for GET_NEXT and GET_INTERMEDIATE
You might get a clue from this..
[code ]
} else if (purpose == nxopen.uf.UFDpud.Purpose.GET_NEXT) {
double proj[] = {0.0,0.0,-1.0};
drpos0 = dpSess.askDrpos0(dpudPtr);
coord = path.getNextCoord();
if(coord==null){
ufDrPos.createFinalLift(drpos0);
}else{
pos[0] = coord.x;
pos[1] = coord.y;
pos[2] = coord.z;
ufDrPos.setPosition(drpos0, pos);
if(id==0){
ufDrPos.setProjVec(drpos0, proj);
ufDrPos.createFirstCut(drpos0, pos, dir);
else{
ufDrPos.createCut(drpos0, pos, dir);
id++;
} else if (purpose == nxopen.uf.UFDpud.Purpose.GET_INTERMEDIATE) {
UFVariant drpos1 = null;
UFVariant drpos2 = null;
// System.out.println("purpose GET_INTERMEDIATE");
final double ratio = dpSess.askRatio(dpudPtr);
drpos1 = dpSess.askDrpos1(dpudPtr);
drpos2 = dpSess.askDrpos2(dpudPtr);
double[] pos1 = ufDrPos.askPosition(drpos1);
double[] pos2 = ufDrPos.askPosition(drpos2);
double deltaX = pos2[0] - pos1[0];
double deltaY = pos2[1] - pos1[1];
double deltaZ = pos2[2] - pos1[2];
double midpos[] = new double[3];
midpos[0] = deltaX * ratio + pos1[0];
midpos[1] = deltaY * ratio + pos1[1];
midpos[2] = deltaZ * ratio + pos1[2];
ufDrPos.setPosition(drpos0, midpos);
id++;
} else if (purpose == nxopen.uf.UFDpud.Purpose.REWIND) {
System.out.println("purpose REWIND");
} else if (purpose == nxopen.uf.UFDpud.Purpose.STOP_PROCESSOR) {
System.out.println("purpose STOP_PROCESSOR");
id=-1;
// must unload so NX don't crash
unloadType = BaseSession.LibraryUnloadOption.IMMEDIATELY;
} else {
System.out.println("Purpose ??");
[/code]
CODE -->
} else if (purpose == nxopen.uf.UFDpud.Purpose.GET_NEXT) { double proj[] = {0.0,0.0,-1.0}; drpos0 = dpSess.askDrpos0(dpudPtr); coord = path.getNextCoord(); if(coord==null){ ufDrPos.createFinalLift(drpos0); }else{ pos[0] = coord.x; pos[1] = coord.y; pos[2] = coord.z; ufDrPos.setPosition(drpos0, pos); if(id==0){ ufDrPos.setProjVec(drpos0, proj); ufDrPos.createFirstCut(drpos0, pos, dir); } else{ ufDrPos.createCut(drpos0, pos, dir); } } id++; } else if (purpose == nxopen.uf.UFDpud.Purpose.GET_INTERMEDIATE) { UFVariant drpos1 = null; UFVariant drpos2 = null; // System.out.println("purpose GET_INTERMEDIATE"); final double ratio = dpSess.askRatio(dpudPtr); drpos1 = dpSess.askDrpos1(dpudPtr); drpos2 = dpSess.askDrpos2(dpudPtr); double[] pos1 = ufDrPos.askPosition(drpos1); double[] pos2 = ufDrPos.askPosition(drpos2); double deltaX = pos2[0] - pos1[0]; double deltaY = pos2[1] - pos1[1]; double deltaZ = pos2[2] - pos1[2]; double midpos[] = new double[3]; midpos[0] = deltaX * ratio + pos1[0]; midpos[1] = deltaY * ratio + pos1[1]; midpos[2] = deltaZ * ratio + pos1[2]; drpos0 = dpSess.askDrpos0(dpudPtr); ufDrPos.setPosition(drpos0, midpos); id++; } else if (purpose == nxopen.uf.UFDpud.Purpose.REWIND) { System.out.println("purpose REWIND"); } else if (purpose == nxopen.uf.UFDpud.Purpose.STOP_PROCESSOR) { System.out.println("purpose STOP_PROCESSOR"); id=-1; // must unload so NX don't crash unloadType = BaseSession.LibraryUnloadOption.IMMEDIATELY; } else { System.out.println("Purpose ??"); }RE: Custom CAM toolpaths in siemens NX
Very thanks for your collaboration...
You save me
you solve all my problems...Thanks a lot
as example, can i use a surface like a drive or make a contour like mill contour multi axis operation??
I wait anxious your help...
I don't have any simple example but as you see in my code I have a object named path. It is created from a NX curve. The curve is divided into small segments depending on the resolution I need. Each time I call (or actually NX calls with Purpose.GET_NEXT) path.getNextCoord() it will return the coordinates of the start of the next segment. These coordinates are used to to set the drivegeometry with ufDrPos.setPosition(), when there are no more coordinates i run ufDrPos.createFinalLift()
NX will continue to call the dpud until you run ufDrPos.createFinalLift() if you don't do that you will end up with a infinite loop.
I have never tryed to use surfaces as drive..
