Output profiles/elements summary for weights
I went around looking for a way to plot a table with all the lengths of frame members. If you could have profile weights there, so much the better.
Anybody holds a clue to that? It seems ridiculous a software like sap2000 would have the option in a tick!
RE: Output profiles/elements summary for weights
Use Display>Show tables and checkbox the reporting option for Connectivity Data>Connectivity data - Frames in order see the lengths of each frame member. For selfweight, you can get total weights by Object type or section using Display>Show tables>Miscellaneous data>Material list. You can also right-click individual members to view their length using the Location tab
