RTD input to PLC...
RTD input to PLC...
If a PLC does not have a special RTD input module, what is the best way to be able to read a RTD input with the PLC? Can an analog voltage or current input card be used with accuracy? Or are there economically feasable devices to convert the signal from the RTD? Any suggestions?
The RTDs are all 100ohm Platinum.
Mmmmmm.
Mmmmmm.
RE: RTD input to PLC...
