Failing steel sections in reference to thread750-258816
Hi everyone
In reference to thread750-258816: Failing Members!!!, I have also the same problem. I tried the suggestions from thread750-258816: Failing Members!!! but still I cannot achieve any good results. I am analyzing a steel tower...
If I use Interactive Steel Design, it gives me some physical column members that have odd sizes. Is there a way to make group command which is the same with the Staad modelling and just tell Interactive steel design to produce the same sizes as the other ohysical members?
I have attached here the staad file for reference... Thank you for everyone's help.
Trisha
Trisha
