Ground Beam Design
Ground Beam Design
Ground Beam Design
I am looking at a ground beam that can be subject to tensile and compressive axial loads (under seismic conditions) but also supporting a block wall.
I need help on how I can combine the effect of the bending moments due to the wall and the seismic axial loads in my design. Please see the attached sketch. Thanks in advance.
RE: Ground Beam Design
your link is attached to your desktop
Your beam should be designed considering interaction of both bending and axial loads. You should use the load combinations from Chapter 2 and 12 (as applicable) of ASCE 7. Load combination specific load factors should be applied to bending and axial. Don't forget to add the vertical component of the seismic force (.2SdsD) in the calculations.
Yes, interaction of axial force and bending moment should be considered, under the corresponding load combination.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
