overheating of condenser from chiller unit
hello
we have a chilled water unit, this unit is installed outside in an environment where the ambient temperature is very high as there is a sandstorm
the problem is that the condenser of this unit is exposed to direct these changes ie the fins are not protected against excessive temperature and obstruction and fans operate continuously
my question is how to protect the condenser (it comes like that) against the overheating and there has equipment to add.
cordially
cordially
RE: overheating of condenser from chiller unit
Reduce the amount of heat that you are trying to reject.
Increase the amount of air you move through the condenser.
TTFN
