Weldment
Weldment
Not sure how to add the hole wizard hole to a separate mirrored body. I have a frame with rail welded support blocks. The blocks are patterned down the rail and mirrored to the other side. I can get the holes on one side in the hole wizard with feature scope and selecting the bodies. When I mirror the hole wizard holes (mirror, feature, geometry pattern, feature scope) it is visually correct but doesn't populate my drawings hole call out correctly. Only half the of the holes are called out on the drawing. Obviously I can manually edit the hole call out on the drawing but I'd rather have SW add them up correctly. I think the problem is the selecting geometry pattern in the mirror. Not sure how else to get the holes to mirror though.
Grant
Grant
Certified SolidWorks Associate
SW2009 X64 SP4.1
Dell Precision T3600
Nvidia Quadro 4000
Xeon 3.2GHz Quad Core, 8GB RAM
Win 7 Pro X64
RE: Weldment
RE: Weldment
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
RE: Weldment
RE: Weldment
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
RE: Weldment
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
RE: Weldment
RE: Weldment
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
RE: Weldment
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
RE: Weldment
Would the actual physical parts be drilled & tapped at the assy stage?
RE: Weldment
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
RE: Weldment
RE: Weldment
SW2009 X64 SP4.1
Nvidia Quadro 4000
Win 7 Pro X64
