TitleBlock Updating
TitleBlock Updating
I use Win2000Pro and SoildWorks 2001+SP3.
I have a drawing which contains 11 sheets. Is it possible to update my titleblock to cover all drawing sheets or do I need to do each sheet on an individual basis?.
Drawing rev #, change details, last change author etc.
Thanks, SteveMS
Thanks, SteveMS
RE: TitleBlock Updating
Bradley
Thanks very much!
SteveMS
Select Insert Object from the menu. This will bring up a dialog box where you insert an excel worksheet to create your revision block or you can insert an existing excel worksheet that you have set up already.
Once the excel object is inserted you can right click on it to specify if it to display only on the current page or to display on all pages.
I use this method as it provides flexibility for the length of the change description as well as the size and location of the revision block itself.
