C vers Assembler
C vers Assembler
I was recently in a discussion with a group of younger engineers who have a problem with code space in a micro.
The code including I2C and serial communications is all written in C and the code space limitation is a major problem for upgrading the product.
I suggested that I would rewrite the stable parts of the code (now well proven) in assembler to produce faster and tighter code as I have done many times over the years. - works well for me, takes a bit longer, but the algorithm and interface are proven at this point.
I was surprised with the reaction that I got, basically, while this approach may have been true in my day, modern C compliers produced smaller code than assembler, so my suggestion would not work.
This is news to me, and to others that I have spoken to.
Any comments?
Any comments?
Mark Empson
Advanced Motor Control Ltd
RE: C vers Assembler
In most cases, the ROI for hand-coding versus compiler is often negative, so many choose to stick with compiler output. However, in your situation, you need the space, so hand-coded assembly is pretty much the only way to go.
That said, rewriting "well proven" parts of code also places them squarely back into the non-"well proven" box, so don't argue that point too loudly. You may get a few bytes out of peripheral management code like I2C, but since you're already pretty close to the registers at that point, the gain will likely be minimal in the grand scheme of things. Where you will see your major improvement is in complicated pieces of code, ones where the compiler could not make the correct assumption and therefore added in a lot of dead weight. Looks for sections of repeated code that could be turned into function calls, nasty if/then/else statements that go on forever, etc. Of course, with well-written code, this kind of stuff shouldn't be in there in the first place. Sometimes, refactoring your codebase is a better solution... how can you solve problem 'X' using a different (but shorter) method, like calculating a value instead of using a look-up table.
Dan - Owner
http://www.Hi-TecDesigns.com
I also agree than re-visiting the basic assumptions and architecture of the code is possibly beneficial. We once had mathematical transform code that could be reduced in complexity by 98%, just by exploiting the symmetry of the hardware design.
I would assume that your compilers are sufficiently optimizing that it strips out library routines that aren't being referenced, but there still may be a few holdouts in any linked libraries.
TTFN
I have even seen a crew build a bunch of 8035 code 'by hand', as lists of addresses of atomic subroutines to be executed by a tight loop, without realizing that they had almost reinvented FORTH, the hard way, at considerable expense. The product in which that code was embedded was fairly successful, but had no code space to spare for enhancements, and bug fixes were a super bitch.
I am not aware of any C compilers, modern or not, that can match the density of FORTH binaries. Some of them can beat the speed.
Mike Halloran
Pembroke Pines, FL, USA
Dan - Owner
Mike Halloran
