ASTM A694 INQUIRY
ASTM A694 INQUIRY
Dear all,
Does any of you have knowledge/experience with this material under ASME VIII Div.1? (I wasn´t able to find it in the code). From what I´ve got from the web, is a high yield micro alloyed steel. This material is being proposed by a world famous Q.O.C. fabricator, so I "believe" they are right but I need to check by myself. What I do need are welding data (P number), material properties,etc. Any source where I can get this from?
We need to weld it to A516 Gr70 and would like to know is available PQR´s are valid for this material combination.
Any comment/suggestion are very welcomed.
RE: ASTM A694 INQUIRY
A694/A694M-00 Standard Specification for Carbon and Alloy Steel Forgings for Pipe Flanges, Fittings, Valves, and Parts for High-Pressure Transmission Service
Copyright 2002 ASTM International,
West Conshohocken, PA. All rights reserved.
1. Scope
1.1 This specification covers forged or rolled steel pipe flanges, forged fittings, valves, and parts suitable for use with high-strength transmission-service pipe.
1.2 Several grades of material, based on minimum yield strength requirements, are covered, as indicated in Table 1.
1.3 Supplementary Requirements are provided. Supplementary Requirement S1 is provided for use when purchaser approval is required for repair welding.
1.4 This specification is expressed in both inch-pound units and in SI units. However, unless the order specifies the applicable "M" specification designation (SI units), the material shall be furnished to inch-pound units.
1.5 The values stated in either inch-pound units or SI units are to regarded separately as standard. Within the text, the SI units are shown in brackets. The values stated in each system are not exact equivalents; therefore, each system must be used independently of the other. Combining values from the two systems may result in nonconformance with the specification.
2. Referenced Documents
A53/A53M Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and Seamless
A106 Specification for Seamless Carbon Steel Pipe for High-Temperature Service
A381 Specification for Metal-Arc-Welded Steel Pipe for Use with High-Pressure Transmission Systems
A707/A707M Specification for Forged Carbon and Alloy Steel Flanges for Low-Temperature Service
A788 Specification for Steel Forgings, General Requirements
A961 Specification for Common Requirements for Steel Flanges, Forged Fittings, Valves, and Parts for Piping ApplicationsASME Standards:
ASME B 16.5 Steel Pipe Flanges and Flanged Fittings
ASME B 16.9 Steel Butt-Welding Fittings
ASME B 16.10 Face-to-Face and End-to-End Dimensions of Ferrous Valves
ASME B 16.11 Forged Steel Fittings, Socket Welding and Threaded
ASME B 16.28 Wrought Steel Butt-Welding Short Radius Elbows
ASME B 16.47 Large Diameter Steel Flanges
B and PV Code Section IX, Welding QualificationsMSS Standards:
MSS SP-44 Standard for Steel Pipe Line Flanges
MSS SP-75 Specification for High-Test Welding Fittings
MSS SP-95 Swage (d) Nipples and Bull Plugs
MSS SP-97 Integrally Reinforced Forged Branch Outlet FittingsAPI Standard:5L^REFDOCTITLE: Specification for Line Pipe
Index Terms
high strength low alloy steel; pipe fittings; steel; piping applications; pressure containing parts; steel flanges; steel forgings, alloy; steel forgings, carbon; steel valves
You can order the whole standard online from this site.
Obtain a copy of the specification - check out the mechanical properties and chemical composition.
