twirly thing
twirly thing
twirly thing
I'm a new user of gfortran and am wondering how you implement
a non-advancing write.
The following code fragment works fine under IVF.
CLOSE(UNIT=6)
OPEN(UNIT=6, CARRIAGECONTROL='FORTRAN')
DO I = 1, 1000
WRITE(6, 10) '/'
WRITE(6, 10) '-'
WRITE(6, 10) '\'
ENDDO
10 FORMAT('+',2A)
CLOSE(UNIT=6)
OPEN(UNIT=6, CARRIAGECONTROL='LIST')
Thank you.
RE: twirly thing
Try something like this
CODE
program main
   character(len=1):: bksp
   bksp = char(8)
   do ii = 1, 2000
      write(*, 10, advance='no') '/', bksp
      write(*, 10, advance='no') '-', bksp
      write(*, 10, advance='no') '\', bksp
      write(*, 10, advance='no') '|', bksp
   10 format(2A)
   end do
end program main
This loop finishes in no time so you might want to think of some sort of delay in between the writes
RE: twirly thing
Backspace, Duh!!!
Working now thank you.
SUBROUTINE DELAY(INC)
! INC - NUMBER OF 1/1000'S OF A SECOND DELAY
IMPLICIT NONE
integer, intent(in) :: inc
INTEGER ITIME, ITIME0
integer, dimension(8) :: time_array
call date_and_time(values=time_array)
itime0 = time_array(5) * 3600000 + & ! hour
time_array(6) * 60000 + & ! minute
time_array(7) * 1000 + & ! second
time_array(8) ! milli second
do
itime = time_array(5) * 3600000 + & ! hour
IF(ITIME >= ITIME0+INC) exit
enddo
END SUBROUTINE DELAY
