Connecting surfaces that do not meet parametrically
I have two surfaces that do not meet parametrically and I need them to meet somehow even if they aren't tangent. I run into this problem all the time with igs files. I've left an attachment of a screen shot just to give an idea of what I'm looking at.
RE: Connecting surfaces that do not meet parametrically
This is solve the majority of problems. However, two other common problems with IGES files tend to be:
1. Missing surface (solution is to build replacement surface), and
2. Duplicate surface (solution is to delete one)
In CATIA V5, ruled surfaces are created with the SWEPT surface command and selecting two curves.
If you're creating missing surfaces, the FILL command is useful.
