How do I convert an iges file to a solid
I need to get a volume on a part that came in as an igs file. Is there a way to convert all those surfaces to form a solid. I tried selecting all the surfaces and using the Join icon but it just gave me a bunch of errors.
RE: How do I convert an iges file to a solid
use the join with the automatic selection from the distance propagation option...
You might have to increase the merging distance...
Eric N.
You can use the join feature but this time deselect the "check continuity" option and press the "add mode" button. Finally close the joint feature with "close surface".
Hi! itsmyjob,
Can you please explain me the use of the "Distance Propogation" option in the Join command in the GSD Workbench ?
Himanshu
it is a way to select all adjacent elements automatically. If the IGES file is OK, the automatic selection will give you a closed join. If you have tolerance problem or duplicate surfaces it will show thanks to the propagation.
Eric N.
I've been working with a surface I'm using to split a solid. But I cannot fill some of the holes that are on the surface. I can fill a couple of them. I've been using the "Boundary", "Extract", then "Fill" commands and it worked on a couple. Then I would "Join" the Fill to the rest of the surface to make it one surface. I've attached the model below. Let me know if anybodies got any ideas.
Hi! Jashe,
I have worked on your cat part & resolved your problem, just refer to the Geometrical set "solution" at the bottom of the tree which contains my work features.
Just refer "Healing.1" feature if the merging distance & distance objective deviations are acceptable to you or not.
Himanshu
