Why subtract SUS from OPE?
Hello
I have the next question about LOAD CASES in CAESAR II
Why not simply use L3 = T1 (EXP)?
RE: Why subtract SUS from OPE?
Because the Expansion Case is defined as a range. In order to compute a range you have to subtract two quantities. Furthermore, OPE-SUS will take into account any difference (including boundary condition changes and weight redistribution) between the two cases.
Using L3=T1 is only valid if the system has 100% linear boundary conditions.
Richard Ay
Intergraph CAS
