Infinitely Variable Transmission
why doesnt any auto manufacturers use this IVT?
http://www.torvec.com/technology/infinitely-variab...
http://www.autoblog.com/2006/08/07/torvec-targets-...
RE: Infinitely Variable Transmission
They will inevitably find their way into trucks when they can fulfill their promise _and_ survive in truck duty. Nobody will commit based on a sample of a mere one technology demonstrator vehicle.
Your friends are _way_ behind.
Mike Halloran
Pembroke Pines, FL, USA
What problem does it actually solve that the current myriad alternatives do not? Comapring your efficiency against a conventional 4 speed auto with TC is a bit of a bad sign, I don't think they are even sold in first world countries any more. My rather boring diesel car has a six speed auto with a pair of dry clutches, I wonder how its efficiency compares with that?
Cheers
Greg Locock
Technically you have a valid point. An IVT would have an infinite ratio range in both forward and reverse directions. Most of these devices are more correctly described as continuously variable over a defined range transmissions, or CVODRT's.
Isn't something like that done in certain hybrids using the electric motor?
That solution was first proposed in the early 70s and they even built one car.
Cheers
Greg Locock
Cheers
Greg Locock
Cheers
Greg Locock
