With Staad.ProV8, can you strength check with reduced E?
I need to run a check with the reduced E due to high temperature. I tried using "code check" and apparently you can only change certain properties and E is not one of them. Is there a different function in staad that would design the member with AISC code but with a user define steel properties?
Thanks.
Thanks.
RE: With Staad.ProV8, can you strength check with reduced E?
DEFINE MATERIAL START
ISOTROPIC STEEL
E 29000
POISSON 0.3
DENSITY 490
ALPHA 6e-006
DAMP 0.03
