Problem in Etabs2013 Regarding Results of M11,M22 for Flat Slab!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have facing one problem in Etabs 2013 Regarding Results of M11,M22 for Flat Slab,
the Results of M11,M22 very small as 176e-6 tonf.m/m.
but other results are normal.
Unit used are Tonf,M,C.
Slab Loads DL=0.15 ton/m2, LL=0.2 ton/m2
Own weight are taken.
what is the problem??????????
