Need Ethernet between points A and B, we have 16AWG TW pairs between A & B, can we convert?
Our new meter located at our transformer came with an Ethernet connection point that would give us a lot of info on our PLC.
We have lots of spare #16AWG shielded twisted pairs close by the transformer jbox. Is it possible to convert a couple of pairs of this #16 and run the Ethernet signal over these cables?
RE: Need Ethernet between points A and B, we have 16AWG TW pairs between A & B, can we convert?
You will almost certainly be able to run RS-485 over a twisted pair provided the distance isn't too long and you keep the Baud rate down. As distance and/or speed increases it becomes less forgiving of cable which doesn't meet the required spec.
Only need two pair for Ethernet don't you?
How far bdn2004 as the electron wiggles?
Keith Cress
http://aboundi.com/Product/etherhighway/etherhighw...
I think the latest flyer said they could put Ethernet down barbed wire. It would be interesting to demo for sure.
I Googled "ethernet over fieldbus wiring."
SceneryDriver
Keith Cress
