CE marking for the package components
For one of the Package , purchased from Europe, CE marking is a Must as per European Directives and vendor has agreed to provide the same. But vendor has said that the Individual itmes say manually operated valves, that are installed inside the package need not be certified for CE marking since the whole package is CE marked. Actually vendor had not purchased the valves with CE marking .
But the Inspector is challenging that CE marking has to be done for each and every item inside the package. Which argument is correct?
RE: CE marking for the package components
If you have manufactured the internal components, then you will need to provide a C of C for the product and that will involve going through each of the 6 steps. If the valve has a working pressure in excess of 0.5BAR differential pressure, then it need to conform to the pressure equipment directive and also the machinery directive.
In effect, you cannot CE mark the whole system unless you can complete a good risk assessment against all of the internal components. If the internal components are not CE marked, then you cannot complete the risk assessment.
The PUWER regulations dictate that any machinery must be compliant. If you cannot be assured of compliance, don't accept the package.
Your inspector is correct.
http://www.hse.gov.uk/work-equipment-machinery/dec...
"partly completed machinery is not in a final state that will allow it to operate and it needs to be incorporated with other parts so it can work as part of the final machine."
"If a product can operate as a machine it must always be fully protected with all safeguards provided, be CE marked and accompanied by a Declaration of Conformity."
