Assign Frame releases ( pinned connection and rigid connection)
Hi Everyone,
I want to confirm some connection detail in ETABS software as i'm beginner in ETABS. I want to connect outrigger beam as rigid to the core wall and pinned connection to the column. In pinned connection node i only release moment in major and minor and rigid connection node i did not release any force or moment. Is that correct?
RE: Assign Frame releases ( pinned connection and rigid connection)
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
