beaing isolator in pressure vessel
hello everyone,
i am planning to use a bearing isolator in a pressure vessel having a high pressure steam of 50 bar,in that there will be a shaft rotating in the vessel.
can anybody please tell me that whether a bearing isolator can prevent the leakege of steam from that??
-akshayjain1010
-akshayjain1010
RE: beaing isolator in pressure vessel
Or maybe a low pressure chamber with a throttle bushing to break down the pressure before installing a bearing isolator (requires bleeding off some steam).
To be honest, getting it wrong with 50 bar steam doesn't bear thinking about so I hope someone else is approving your design.
Most seals work best when the shaft is constantly moving, so it will depend on your application - only you know what it is. ?if there ar elong period of no movement or slow rottion, seals tend not to like it so much - most are designed for pumps and compresosrs where the shaft rotates at a fairly constant speed.
What are you doing in this vessel for interest sake?
