Hydrogen and methane bake-out
As I was searching through the different treads of this forum, I found some good info regarding the bake-out, but there was not much discussion on the practices. I would like your opinion and advice on the bake-out temperature and time. So far the mnost common are the temperatures between 200°C and 400°C, but someone went as far as to recommend the stress relieving temparature. I would also like some advice on what codes or scientific articles could be helpful in establishing and justifying this requirement.
Putting Human Factor Back in Engineering
RE: Hydrogen and methane bake-out
The specified temperature should not exceed that of tempering (otherwise a reduction of hardness will ensue).
http://www.welding-advisers.com/
