RC slab / plate analysis 2D or 3D analysis
Hi all. I have been studying the CSI safe program for RC slab/plates. One of the analysis option is to analyze the slab/plate in 2D (meaning only the following is considered: rotation at the two horizontal axis and translation in the vertical axis). I have always thought that RC slab/plates should only be analyzed as a 2D element, if we are considering gravity loads only. I believe that the axial loads on a slab caused by frame action is negligible and thus can be ignored in the analysis and design of the slab/plate.
My question is: when would the 3D analysis be useful? does SAFE wants us to consider the axial loads?
RE: RC slab / plate analysis 2D or 3D analysis
Many people are going towards the way of plate elements for the analysis of floor slabs but design-wise strips need to be considered. This is for strength, service and deflection calcs. I don't know what theory some of these FE-RC programs are applying to calculate out deflections.
If you type Wood Armer, Mxy into the search tab above some good threads so come up. Here's one that had a good a lively discussion thread588-259325: Capabilities of today's 3D FEM slab design programs
Moment curvature analysis,reinforced concrete column design and prestressed concrete pile design at www.structurexpress.com
