Api 650 tank data sheet with 110¦c design temperature
I am checking several tanks data sheets, in two of them the design temperature is 100°c and 110°C.
Is any appendix in API 650 considering the condition for 110°C.Or I have to design wiht API 620
The reference document is API 650 eleventh edition add.3
I have API 650 11th edition add.2
RE: Api 650 tank data sheet with 110¦c design temperature
In the case of SS tanks
Does data sheet should indicates the S.3.6 APPENDIX M modification and the limit temperature should be 40°C?
Let me tell you my interpretation:
S.3.6.1 means that the M requirements for higt temperature tanks must be applied after 40°C in SS tanks.
Please correct me if I am wrong.
Do you agree that since S.1.2 demands that the lowest maximum temperature is 40C then most Annex S tanks will be Annex M tanks also?
Yes sir I agree
Then S and M should be followed.
Nice topic to read this one. I was reading the API650 and I would say that all the annex S tanks would be annex M tanks also.
Can you please give me an example of an annex S tank which wouldn´t be a annex M??
Thanks.
I thought so. I just got a bit confuse about the "most",English isn´t my native language.
Thank you guys for such a good topic.
