Flange
Flange
Hi team,
Need ur Opinion
Observed some discrepancy in material certificate.
Requirement is API 6A, 5000 psi rating Flange,PSL2,TEMPERATUE CATAGORY IS ''U''. But below mentioned deviation has observed.
-As per API6A 5000 Psi rating, impact test temperature required for U category is minus 18, but certificate mentioned as 20C.
-And certificate has mentioned that material description is like ''ASTM A105N SOUR NACE API 6A # 5000 ''.
Apart from normal requirements ,any other special testing is required for API6A?
How manufacture giving compliance ''ASTM A105N SOUR NACE API 6A # 5000 ''??
