Interaction Diagram for 12"CMU
Where can I find interaction diagram for 12" CMU wall. I was looking at NCMA TEK and found TEK 14-5A that is for 8" CMU walls. Any idea how can I find the same tables for 12"CMU?
RE: Interaction Diagram for 12"CMU
If you wanted it is not incredibly difficult to create one for yourself in any spreadsheet program. If you have ever done the calculations by hand then it takes no longer than running the hand calcs in full.
The best part is you can input different rebar specs into your spreadsheet and it will recalculate the interaction diagram.
The reason you only can find 8" walls is that the 8" walls and structures are general standard for in masonry industry globally. The second most common wall thickness are 6" and 12" for high performance walls. The 28 story Excalibur in Las Vegas was 8" for 26 of the 28 floors with the lower two floors 12" because of the larger open areas. Buildings with 6" partially reinforced 6" walls designed under ACI 530 are very common for buildings internationally up to 22 stories.
Often, the published diagrams are used as supporting material for designs, so it is a liability situation.
Creating something like a very wide application document for all conditions is a major undertaking especially with keeping it current to the new changes in the code standards and changes. Fortunately, the NCMA TEKs are written by the same people that do much of the codes, material standards and and documenting for the writing of the codes. The original ACI 530-02 was written using a 15 year old design standard and incorporating all research as support for the final document that was not legally published in 2002.
Industry references and codes are a true example of documentation for use in a "belt and suspenders" standard that mat be used properly or very irresponsibly. Codes and standards are just as slow to change. I can remember being on am ASTM material committee after 10 years of waiting to be a voting member and working for 5 years on a new material standard.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
