Block UI Styler - hide default buttons
Hello
I'm using NX 7.5.5. I've tried to create dialog with no default buttons in the bottom part of the window (OK, Apply etc), just "x" button in the top right corner. Is this possible? I know that it can be done with Pre-NX6 UI Styler, but I wanted to use more modern tool :)
P. Sulikowski
RE: Block UI Styler - hide default buttons
In the dialog properties, general, other, set LightweightMode to True - this may be what you are looking for.
Mark Rief
Product Manager
Siemens PLM
I got only Dialog sizing option under Other in dialog general properties.
You are correct - I was looking at something else.
Sorry about that ;*(
Mark Rief
Product Manager
Siemens PLM
