Gas leak through a hole in the pipeline
Hello all,
I need to calculate the flow rate of gas leak from a pipeline coming from gas well where some water and condensate are produced also. The leak is from 130 psig pipeline pressure to the atmoshpere. What is tbe best equation to use?
Thank you..
Thank you..
RE: Gas leak through a hole in the pipeline
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
David Simpson, PE
Holes only ever get bigger in my experience...
https://exchange.dnv.com/publishing/Codes/download...
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
David Simpson, PE
Calculating Accidental Release Flow Rates From Pressurized Gas Systems
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
David Simpson, PE
This is really good info.
they'd trace the figure on graph paper, cutout the figure with scissors, weigh the paper on a lab balance and compare the weight to a chart they'd made from various weights of cutouts of 1 square, 2 squares, 4 squares, 9 squares, etc. The lab tech used a planimeter to calculate area for Y-t data, but the X-Y data area calc was like my sister making paper dolls.
