Power Factor - Power Consumption
Magnetizing current consumes no power. Reactive power is not real. However, the current in the wires is real. As I understand it, the reactive power DOES actually consume energy each cycle but it is like a spring. It compresses/decompresses/compresses, etc. providing the energy for the next cycle. The reason a low PF is bad is because the cables that supply the motor, or the cables that supply your residential area, have a curernt capacity associated with them, and thus when a low PF exists, the current in the wires is higher than it needs to be... which results in heat dissipation losses. THEREFORE, the magnetizing current DOES actually result in energy consumption, just not in the intended load. Heat dissipation is real. Energy cannot be created or destroyed. It can just change forms... This is why you get charged a lot for buildings that have low PFs because the utility company doesn't care and is simply charging you for the total energy consumed, both in the distribution lines and in the loads in your building. Is this correct logic!? Please, I am going crazy trying to comprehend this.
RE: Power Factor - Power Consumption
The conductors do indeed have a power loss which limits their capacity to carry current, but the value of that power loss isn't the main concern. The problem for the utility is that they would ideally like to use those conductors to deliver energy to loads. A low power factor load means that they have to use a significant portion of their conductor's capability carrying reactive current, leaving less capacity for delivering real power. Phrased differently, to to deliver a given amount of power to a low power factor load they need a much bigger and more expensive conductor than they would at a high power factor. In the case of a transformer, which is rated in VA rather than watts, they would have to pay for a much larger transformer, containing more core steel, more copper, and more oil, requiring a bigger and more expensive substation equipped with larger circuit breakers. The same reasoning applies to generating plant.
The quick answer is that low power factor loads make inefficient use of the transmission and distribution system, so the operators naturally pass on some of this cost to those who have low power factor loads through penalties.
Scotty brings other important points... effect on supply system. The vars have to be "generated" and transmitted. This uses equipment and capacity and also alters the voltage profile.
I think scotty left out a crucial and central technical point, though: Suds in your glass leave less room for beer.
(2B)+(2B)' ?
So in essence, a utility can meter anything. It can also charge fees in any manner to give customers an incentive to correct their power factor.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
(2B)+(2B)' ?
(2B)+(2B)' ?
I agree with you, which concern is largest will depend on the situation. I think Scotty was just directing your attention to another aspect which is potentially more important than the cost of generation associated with supplying that I^2*R if the local network is already taxed to capacity (remembering that generation cost tends to be a lot less than consumer cost).
(2B)+(2B)' ?
electricpete, when you say consumer cost, are you meaning distribution networks? All the power lines, transformers, substations, etc.?
consumer cost - how much does energy cost the user. Almost 20 cents per kw-hr in my neck of the woods.
generating cost - how much does it cost the utility to generate the energy. In my neck of the woods it is around 2 cents per kw-hr, excluding generation capital costs. A factor of 10 lower. Because utility also has to build and maintain the T&D infrastructure to deliver the generated power to the user.
How much does a given kw-hr of I^2*R loss cost the utility?
Convert it using the low generating cost, not the high consumer cost.
(2B)+(2B)' ?
Just to ratify my understanding. Say, for instance, a small genset was running a little induction motor. If all the cabling and everything in the system was sized so as to account for all possible reactive power (view everything as sunk costs), there would be no issues with a low PF. Please tell me this is correct.
Keep in mind as others have said, the I^2R losses are the power companies problem mostly, not yours, and are a small precentage of the total so don't get it blown out of proportion....
with that thought, even if you have low PF, if you size YOUR generator to YOUR loads nameplate data, it will COVER you. Don't get caught up thinking low PF will make YOUR loads bigger than nameplate data; ie., if you have a 100amp nameplate rated motor, you will likely size your wiring for 100 amps..... if that motor is unloaded, it may draw only 1 amp of REAL power (that u pay for) but still 40 amps of imaginary, so PF will be real low, but it is SSTILL way less than the 100amps YOU sized for....
I looked up the circuit for a PF correction capacitor and a motor. It shows the capacitor in parallel with the motor. So I guess the power supply wires will only carry 1 amp of current and the wires connecting the capacitor will carry 39 amps (for the no load case).
If motor was drawing FLA and you had 100% correction (you shoudln't have that much if caps are switched with motor) then the real component supplied upstream of capacitors would be sqrt(100^2 - 40^2) = 91.6A
(2B)+(2B)' ?
Please god tell me this is right...
A 1 kW motor at 100% power factor will require 1 KVA transformer capacity.
A 1 kW motor at 50% power factor will require 2 KVA transformer capacity.
If you don't like it, correct your power factor. ROIs are often less than one year.
Bill
"Why not the best?"
Jimmy Carter
remember that the reactive current is exactly 90 degrees out of phase with the real current (ELI the ICEman). so the math is like finding the lengths of the sides of a triangle not algebraic addition and subtraction; hence the sum of the squares.
when a motor is loaded, the reactive current goes up due to leakage inductance inside so the 40 amps no load in my example is probably closer to 50 or 55amps at full load; so the math shows probably sqrt[100^2-55^2] or 83amps real for a more realistic .83 pf....
Just to be clear something up, Your local electrical code will tell you that you can never size the feeder wire to a motor by using the corrected current. There are good reasons why sizing the feeder cable to match the motor rated current is not overkill, such as the capacitor failing and being able to start the motor without an excessive voltage drop.
So examples of 0% or 10% PF are just theoretical examples, not normally seen in the real world.
To which I respond: 'It depends on your world...'
In my working world, we use capacitors to 'supply' the lagging vars drawn by the predominantly inductive loads connected to the grid. What we call 'low-voltage' caps [meaning with a phase-to-phase voltage of 14, 28 or 44 kV] typically have a rating of between 10 and 30 MX. Our directly-connected 'high-voltage' caps [either 115 or 230 kV] range from 96 up to a whopping 410 MX output.
Most of the HV caps and a number of the LV ones have smoothing reactors installed in series with their connection to the grid to dampen that initial 'kick' when they're placed in service. Alternatively, depending on the location of the installation and the electrical characteristics prevailing there, independent pole operation breakers may be utilized to very precisely time the individual contact closure to co-ordinate with the null or zero-crossing point in the waveform so as to facilitate smooth insertion.
On the opposite side of the fence, we also use reactors to absorb VARs from the system, particularly in association with 500 kV circuits which generate great amounts of 'lagging' VARs when lightly loaded...
But I digress.
Capacitors have almost a perfectly leading power factor; reactor have very close to a lagging power factor. The switching duty is severe, particularly for cap switching, and sulphur-hexafluoride-insulated [SF6] breakers are gradually replacing the older oil circuit breakers in LV applications.
A factor that often bears on power system operation is the need to transport large amounts of power from where it's generated to where it's used; and as an earlier poster alluded to, peak times are the worst. During these periods especially, proper deployment of reactive resources can be used to optimize the delivery limit of a circuit which might otherwise be constrained due to either thermal or stability limits. [We have also recently commissioned series capacitor installations to improve the ratings of some of our 500 kV circuits.]
A final note: capacitor output is all or nothing, and varies as the square of the applied voltage. Reactors have a similar characteristic, but since it's based on frequency and since there is typically far less variation in frequency than in voltage profile, VAR consumption by reactors is almost pegged...
The latest thing is to use Static VAR Compensators [SVCs] which consist of a combination of reactors and thyristor-switched capacitors; SVC's can thus have a soothly adjustable 'lagging' reactive buck / boost function, for example, from 40 MX 'in' to 60 MX 'out.' As a power system operator, I consider these the cat's miaow; they're almost as good as a synchronous condenser...
Autotransformer tertiary windings often prove a very handy place to hook these gizmos up.
Hope this was at least interesting, even if it didn't help...
CR
