changing position of dimension text
please look at the picture attacched. i can't solve the question because i don't know where find the setup string
RE: changing position of dimension text
CleanUp Tab#1 Spacing,SnapLine,BreakWitness
CleanUp Tab#2 FlipArrows,CenterText
For Dims you want to unflip arrows of they can be selected as group and you can drag using main mouse button and then flip all by tapping Right Button.
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
dim_text_gap: ratio to text height that sets distance between dim line and value.
draw_arrow_length: length of dim arrow >
dim_leader_length: sets leader extension when arrows are outside
The other thing to check is your drawing units make sure metric values are not being set in inches. Setting dim gap to 0 or.01 should fix issue I've tested arrow length and seen arrows overlapping while pointing outwards. If the text gap isn't small enough the arrows will be flipped.
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
= ProE = SolidWorks
