Belleville Washer - Torque calculation @ working load
Hi
Could somebody help me how to calculate torque applied for parallel stack of Belleville washers at working load.
I am trying to use following Belleville Washers.
.380" ID, .750" OD, .056" Thick
Deflection @ working load = .007/Working Load = 430 lbs/Flat load = 845 lbs.
I would like to set 3 of these as parallel stack so that deflection remains same but load multiplies.
How to calculate toque applied for a working load of 1290 lbs (3 X 340 = 1290)??
thanks,
pkpavv
thanks,
pkpavv
RE: Belleville Washer - Torque calculation @ working load
http://www.portlandbolt.com/technicalinformation/b...
