VBA CATIA Help: Complex Macro
Hi there,
I have next to no experience with VBA and creating macros in CATIA. I've been given the task of creating a method that can calculated the area of empty space in a CATIA Part using image processing software. The macro will involve finding an overall dimension of the part, the outer diameter for instance, creating a sketch involving two circles, one of which corresponds to the diameter measured. After which the sketch will be padded, the view rotated to the front and a screenshot taken. The macro is then required to launch an external image processing program and insert the screenshot. The image is then analyzed using another macro I've created. The software calculates the area of interest and pastes the results in an excel spread sheet. It is then necessary to insert the final value from excel back into CATIA and display it somewhere.
I've already made a macro to create the sketch and pad it but I'm not sure how I can create a macro that measures the overall dimension, this dimension changes for different parts. This is something I can probably figure out but I was wondering if someone could help me with changing the view to the left orientation and taking a screen shot. I recorded a macro for rotatig the view but I get an error when I attempt to run it, I've underlined the area of interest:
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim cameras1 As Cameras
Set cameras1 = partDocument1.Cameras
Dim camera3D1 As Camera3D
Set camera3D1 = cameras1.Item("* left")
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = camera3D1.Viewpoint3D
Dim specsAndGeomWindow1 As SpecsAndGeomWindow
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer3D
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
viewer3D1.Viewpoint3D = viewpoint3D1
End Sub
As for the screen shot, I found a macro but it only works when VBA is open in the background and it takes a screen shot of the wrong window:
Option Explicit
Private Declare Sub keybd_event Lib "user32" (ByVal bVk As Byte, ByVal _
bScan As Byte, ByVal dwFlags As Long, ByVal dwExtraInfo As Long)
Private Const KEYEVENTF_KEYUP = &H2
Private Const VK_SNAPSHOT = &H2C
Private Const VK_MENU = &H12
Sub AltPrintScreen()
keybd_event VK_MENU, 0, 0, 0
keybd_event VK_SNAPSHOT, 0, 0, 0
keybd_event VK_SNAPSHOT, 0, KEYEVENTF_KEYUP, 0
keybd_event VK_MENU, 0, KEYEVENTF_KEYUP, 0
End Sub
Any help, suggestions, or areas you think cannot be done using a macro will be appreciated,
Dave
