Triphasic pump for hot water of low-power
Hello
I need a low-power (about 0,37 Kw) triphasic 230V (50 or 60 HZ) pump for hot water.
The water temperature is about 85-110º.
It is not possible to get this in Europe.
Is possible to get them in other markets?
Regards.
RE: Triphasic pump for hot water of low-power
Assuming this is what you mean, Why on earth do you want a three phase motor for 0.37kw??
As you say it is hot water I assume you don't mean three phase fluid, so forgive my ignorance, but can you explain some more please what "triphasic" means.
three-phase electric power
http://todoproductividad.blogspot.com/
What is wrong with a single phase motor?
