How do we move to layer CSYS when working in assembly
Hi everyone,
Currently working with nx8.5 I found a problem when working with top assembly with lot of part in it.
my template file to create new 3D file include a coordinade sistem or CSYS in it on layer 1.
When working on assembly i use to move object such as sketch, plane CSYS to layer 256 to clean work space.
but now in nx8.5 (and nx8 i think) the filter present in format move to layer doesn´t allow me to select CSYS so i cant move them to another layer.
GTAC say that the only way to do so is to disable CSYS layer ()60 or 62: but in may case i have cad file of standart part that i use from over a decade since unigraphics V15 or so.... most of them with CSYS in layer 1.
Ive change layer of csys for new files i create but old one would take age to change.
Is there a way to select csys so that i can move them to another layer when I´m in top assembly ?
thanks for your help
Jbim
Jbim
RE: How do we move to layer CSYS when working in assembly
www.nxjournaling.com
Also make sure your selection scope is set to "Entire Assembly" (it's the menu next to your Selection filter in cowski's screendump).
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
I have seen the option filter but it simply won t work.
maybe some problem on my pc...
if it work for you it should work for me.
i´ll reinstall nx and remove older version from my pc and see if it solve my problem.
thanks
jbim
