Error with CAM reuse library
I receive the error "The family member saving directory does not exist" when I drag a reuse model to the graphics window. I believe the library is set up correctly; I can see all the reuse models that are supposed to be available but it doesn't work. I checked my ugii_env_ug.dat file for pertinent variables and the only one I found with a familiar name has to do with routing. Any ideas what else I need to do?
NX85
