Penalty Factor
Penalty Factor
Penalty Factor
Hi everyone,
have a problem with the influence of friction when using linear contact.
Model: Solid cube on a rigid shell surface; small accelerations applied in all directions
Problem: solid drift off the plate; (should not because of friction)
Maybe some settings are wrong at penalty factors, can someone explain me these settings?
-penalty factor units
-normal factor
-tangential factor
Brgds
Telly
