change of volume in a rotating shaft.
Hi
I have modeled a simple shaft with to bearings and i apply a torque to the shaft. The problem is that in the results the volume of shaft increases while it is rotating?!
Anybody could give any solution?
Thank you in advance
RE: change of volume in a rotating shaft.
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
