Folding with T3 Aluminium!
Hi guys,
Folding T3 aluminium as shown in the figure is it really that hard? I can see it will be different to that of o-condition al. But achieving the indicated dimension is it possible. Another supplier issues with folding this. They tried using bend radius 1mm did not work and had to changed it to 3mm which he reckons will be taken from the o/all dims to compensate if the highlighted one is to be achieved.
I have been reading up on folding processes and techniques to understand this. They have cut everything first thinking 1mm bend radius will work and when parts cracked he had no other choice but to change the bend radius. Still reckons it is very difficult to be folded.
My question,
T3 Aluminium - foldable or not?
My question,
RE: Folding with T3 Aluminium!
Its yield point is higher than some steels,
and it machines like a dream.
Bending is one thing it doesn't do well.
Resist corrosion is another; that's why the alclad variant came to exist.
Consider a different alloy.
Parts like the one you have illustrated are commonly made from 5052-H32.
... With tight corners. Or 5052-H34 with less tight corners.
Mike Halloran
Pembroke Pines, FL, USA
It's also available in thicker billets, so there may exist the possibility of machining your part from a solid bar with no bending.
It seems crazy, but a CNC mill with a fast spindle and/or a large cutter can go through 2024-T3 like butter, and produce the part at a nearly competitive cost.
The only downside is that chips will be _everywhere_, including stuck to the ceiling.
Mike Halloran
from table 4 page 221 of forming Alcoa Aluminum. Min forming radius for 2024-T3 sheet: Less than 1/64" 1.5 to 3 T , 1/32" 2 to 4 T , 1/16" 3-5 T.
The min bend rad for 2024-0 is 0" so the part can, be formed, by heating, and quenching it, forming it in the AQ temper, hand straightening it, then aging it back to the temper you want. This also means, that you have, to have this done, by a shop with heat treat capability.
B.E.
You are judged not by what you know, but by what you can do.
I have seen 19" rack enclosures bent up from 2024-T3. The bend radii were large, as required. The parts appear to have been cut out with a nibbler. This was probably all done in an aircraft hangar somewhere.
As noted above, 5052-H32 is a standard aluminium grade for sheet metal. 2024-T3 is really exotic, and you should chat with your sheet metal shop before using the material, and/or letting them do the fabrication.
JHG
By the way, do you have mill certs on the material? Have you checked hardness to see if it seems to be 2024-T3?
There is a used copy on Amazon right now, http://www.amazon.com/gp/offer-listing/B00123OWOO/...=
It is an early edition, about the third or fourth printing.
B.E.
There is a later copy available for about $ 28.00 also on Amazon.
B.E.
if you form in O condition and later heat treat to T3 (or T42) you can get tighter bend radius.
Quando Omni Flunkus Moritati
