Using a pattern to drive part width through an expression
Subject confusing enough?
Okay, so I have a pattern of cutouts through a surface. I want the width and height of that surface to be able to grow or shrink based on how many cutouts I apply in my pattern.
Can this be done through and expression or is there another tool I should use to drive it?
Thank you,
John
Thank you,
John
RE: Using a pattern to drive part width through an expression
