boundry to show around detail view
How do I get the boundry around a detail view to show? And show in the same shape as called out on the parent view (rectangle, square, etc.)? Using NX 7.5
boundry to show around detail viewboundry to show around detail view(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: boundry to show around detail view
Format (pull down menu) -> layer visible in view -> click on the detail view -> toogle the layer "on" that contains the border (probably the work layer when the view was created)
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
1. Create a detail view using the Rectangle type (I prefer corner to corner). Within the Detail View dialog, set the Label on Parent value to nothing (for now).
2. Define the detail, place the view.
3. Right click on the detail view and Expand the view. Manually draw the boundary that you want. Ellipse doesn't work. Lines, arcs (circles) and splines do. Expand back out of the view.
4. Right click on the detail view again and select Boundary. Now define the View Boundary as Breakline/Detail. You can set the Label on Parent to be Boundary and your View Dependent curves should now appear over the parent view.
5. Manually add your detail label on the parent view.
Some things to note:
If you need to change the shape of the detail view boundary, you will need to make the boundary Manual first, then edit the View Dependent curve(s) and repeat step 5. Sometimes after updating, brown points may appear around the detail view. A refresh will wipe the display clean.
Hope this helps.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
