embedment of drilled pier into slab
I have a slab being supported by drilled piers. There is only vertical load on the slab. What is the minimum required embedment of the drilled pier into the slab?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: embedment of drilled pier into slab
