Mechanica Connections
Hi
I'm using Creo 2.0
I have a pressure vessel with a cover on top of it.
There is a gasket(Sweet White Rubber) that form the seal between the neck & lid.
The problem is that Creo 2.0 sees this connection as a Rigid connection and deforms the lid the same as the barrel. This is incorrect.
Can someone please help me out here as there are far to much stress on my lid because of this
I'm using Creo 2.0
RE: Mechanica Connections
Are you deforming the barrel through some other pressure or load, and think the lid will "slide" across the gasket so that force won't be transmitted to the lid?
as you will see by my snapshot the lid blows up to the side, the same as the neck but it shouldn't
