ACI Appendix D
ACI Appendix D
I hope someone can help me fully understand the requirements of ACI Appendix D.
I'm having difficulty determining if I should be analyzing my cast-in-place bolts for the baseplate using a "cracked" section analysis, which would apply the reductions to meet the requirements of Appendix D. My controlling load is a 0.9D+1.6WL case. I was under the impression that your section only needs to be analyzed as cracked when checking seismic load cases. I normally always apply the restrictions, but in the case I would be extremely over designing the connection and I also would like to the proper code interpretation.
RE: ACI Appendix D
RE: ACI Appendix D
RE: ACI Appendix D
RE: ACI Appendix D
