Remove PartBody from Body
I'm trying to carry out an CFD simulation of a part. To do so, I need to make a hole inside a box in the same shape of the part. I'm trying to use the Booleam Operation "Remove", however catia shows me the message "PartBody cannot be used to perform boolean operation. Please select another body". The problem is that PartBody is the one that I need to remove from the box( body). Does anyone have a suggestion to solve this problem ?
RE: Remove PartBody from Body
Insert a blank part body, right click, at the bottom you should see an option "change part body". This will make this new blank body the main part body for the catpart, then allow you to remove the body you need.
PartBody can not be negative is the reason for it. Notice your side menus when you have a blank PartBody. All active commands are positive features (pad, shaft, rib,....). Follow Jopal's post and all will be good.
Win XP64
21SP6/22SP4, 3DVIA Composer 2013X, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
It worked!
Thanks a lot Jopal and DBezaire
