Creating roof turbulence on a flat roof
Would creating turbulence on a flat roof by installing multiple small ridges reduce the likelihood of the roof lifting in a strong wind?
RE: Creating roof turbulence on a flat roof
As for lift, I am not an aeronautical, but if you add curvature to the top surface, do you not increase lift, at least up to a point?
Mike McCann
MMC Engineering
There could be local effects due to roof texture or shape which are not accounted for in the code/standards. I would expect harsher design demands with the proposed irregularities. Wind tunnel testing would probably need to be done to validate such a design.
I was hoping for an answer that said yes, more turbulent flow on the roof would reduce the airspeed and therefore likelihood of it detaching, so that I could reduce the structure but .. its better to know the answer than not.
Cheers
