is it possible to make an exe out of an VBA project? or to run a script outside de VB editor?
Hi guys, i was wondering if a could make an exe out of an VBA project, since i couldn't run it from VBS by pasting the code directly into it,
- is there a way to run it outside the visual basic editor?
- should i buy VB6 and try to run it from there?
THANKs in advance.
here's my code
CODE --> VBA
Sub CATmain()
'Declaracion de variables
Dim spabench As SPAWorkbench
Dim mymeas
Dim ref1 As Reference
Dim myans As Double
Dim InputObjectType(0)
'Devuelve el numero de caras de la parte
Set objsel = CATIA.ActiveDocument.Selection
objsel.Clear
objsel.Search "Type=Topology.Face,all"
MsgBox objsel.Count2
X = objsel.Count2
'**************CICLO***************
For i = 1 To 5 'Aqui va x
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set Selection = partDocument1.Selection
Set ref1 = Selection.Item(i).Reference
Set spabench = partDocument1.GetWorkbench("SPAWorkbench")
Set mymeas = spabench.GetMeasurable(ref1)
Dim mycoord(2)
mymeas.GetCOG mycoord
MsgBox mycoord(0)
Next
End Sub
RE: is it possible to make an exe out of an VBA project? or to run a script outside de VB editor?
thanks ferdo, i will be looking a way to do it a post it.
A small modification in your code and it runs from CATScript. Still, you can show us how did you tried to run the macro not from vba editor.
CODE --> CATScript
Sub CATmain()
Dim mymeas
Dim myans As Double
objsel.Clear
X = objsel.Count2
ReDim mycoord(2)
MsgBox mycoord(0) & "    " & mycoord(1) & "    " & mycoord(2)
Next
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
it works now, apparently it is not neccesary to declare the variable type, as follows.
CODE --> CATscript
Sub CATmain()
Dim spabench
Dim mymeas
Dim ref1
Dim myans
objsel.Clear
X = objsel.Count2
ReDim mycoord(2)
Next
End Sub
and it works from a macro .catvbs file outside VBA.
